OS: Windows 10 64-bit
Motherboard: Gigabyte X79-UD3
BIOS: F18
Processor: Intel Core i7-4820K CPU @ 3.70GHz (8 CPUs), ~3.7GHz
Graphics Card: NVIDIA GeForce GTX 660
I'm not really sure how to format this or if I'm doing it right. I'm also pretty inexperienced when it comes to PC workings, so bear with me. I use this PC for web browsing and gaming.
I'm afraid my PC is slowly dying, most of the problems have come about within the past month or two, but the bootloop problem has been ever-present.
I've had this PC for about 3 years now? I've lost count. It was prebuilt from Arrow Computers Australia.
I'll just list the problems in chronological order.
Now, a while ago (a year? I don't know), the PC was updating Windows and something went wrong. It hung on the boot screen with only a flashing underscore. the fix was to completely reinstall windows and format the hard drive (iirc). Maybe this can provide some insight.
Sorry for the information overload, I just wanted to provide as much info as possible.
If someone has any help whatsoever please help! I'm afraid the PC might die at any moment 🙁
Just looking for a solution to any of the above problems, I have a nagging feeling that they're connected.
Thanks!
UPDATE:more corruptions it seems, the Blizzard app is "either not designed to run on Windows or it contains an error. Yay. I'll reinstall the app.
BIOS: F18
1. Nearly every time the PC goes into sleep mode, upon waking it goes into a bootloop, sometimes it recovers on its own after a while, other times I have to hold the power button. After holding the power button it boots semi-normally. In both ways, recovering from the bootloop results in the main BIOS having to be restored from a backup (corruption if I remember correctly).
2. Apps disappeared from the start menu. I've tried a couple solutions but nothing is working. Only a select few apps are appearing in the "all apps" section, the rest aren't there. Trying to open some apps that are visible in the start menu does nothing, the app shortcut is pressed but the app doesn't open and the start menu doesn't close.
3. Every couple times I boot up the PC, I get a notification saying Windows Defender is not on, I go to turn it on but nothing happens.
4. Upon boot, on the motherboard splash screen, disk checking begins (with the option to cancel, of course). The repair becomes very slow and takes a few minutes to go from 52-55% then jumps to 100% complete.
5. Notifications tell me I should scan the drive for errors & fix them. Upon clicking the notification, the security & maintenance panel from the control center opens, with no options to scan & repair drives. The panel tells me all drives are normal.
6. Firefox became corrupt. Suddenly started constantly crashing tabs. After a PC restart, Firefox wouldn't open and an error message displayed saying something was corrupt. Had to do a reinstall.
7. For about 5 minutes during startup (which is now MUCH longer), disk usage is at 100%. The main offenders are:
- Service host: Superfetch
- Antimalware Service Executable
- System
- Various NVIDIA processes, from the GeForce Experience app
8. Overwatch also became corrupt (I think). The launcher couldn't locate core files - including the application itself - after a couple of unsuccessful repair scans through the Blizzard Client, a repair scan and actual repair froze up the PC. After waiting about 10-15 minutes, the PC forced itself to restart with no bluescreen (that I saw). During the repair scan that froze the PC, strange noises started coming from the tower. Not sure how to explain it. Imagine a low vibrating noise for about a second, a second of silence then a very short little buzzing beep. This was constant. Every time the little beep happened/happens, the red light on the tower flashed (hard drive being accessed?). This noise now persists upon boot and startup for about 5 minutes after boot. the noise seems to happen during 100% disk usage.
9. After the above forced restart, a notification shows up saying a USB device I plugged in malfunctioned and is not working, I think it's the NETGEAR USB network adapter, as my PC has no way to connect to the internet. Unplugging and plugging the adapter back in allows me to use the internet, the notification still persists.
10. Overwatch crashed, a graphics card crash. I updated to the latest driver and the problems seem to have gone away.
11. The PC bluescreened! I started up the PC, startup was taking a while and those weird noises were there. Suddenly during this, there was a bluescreen. 'CRITICAL_PROCESS_DIED' This is the first bluescreen I've experienced with this PC. There was a forced restart and a drive repair scan. It took forever, I was contemplating turning the PC off via power button, I thought it was hanging!.
Thanks!
