Gents,
My friend has a 2007 Cabo 40 Sportsfisher and when he ordered the Boat it came with a Nauticomp "Marinized" Computer.
It turns out "marinizing" was installing a Dell GX620 USFF (Ultra Small Form Factor - a Dell term and not a standard motherboard size - it's about 10.3' by 9.7') into a Nauticomp labeled steel enclosure that had the back panel of the PC exposed to make all the connections. It even used the Dell DA-2 power brick into AC to light it up. Of course it came with Win XP and a small 80 Gig Hard Drive, and it used the on board video out (one DVI) one Com Port., and 5 of the 6 rear USB connections.
Of course it's long past it's best before date (It just failed and I'm trying to fix it as a patch for the rest of the season) so he's looking for a replacement. He really only runs one navigation program call Nobeltec (see requirements below) but infrequently some weather software. The PC gets input from the Com Port.
"Minimum System Requirements - higher system requirements may be appropriate if multiple advanced features are used concurrently:
◾Microsoft Windows® 7, Windows® 8 , Windows XP SP3 (*)
◾CPU 2 GHz (Intel i7 recommended)
◾4GB of RAM (6GB recommended)
◾Video Board:
Minimum - dedicated Video Board with 512MB VRAM (ATI or NVIDIA)
Recommended - dedicated Video Board with 1GB VRAM (ATI or NVIDIA)
◾Screen Resolution: 1024 x 800 or higher
◾DVD reader
◾Hard Disk: 40 GB of free memory
◾USB or Serial Port for connecting instruments
◾Network adapter:100 Base-T for NavNet 3D, NavNet TZtouch, or Furuno 2XX7 Series Radar connection
◾Internet Connection for initial installation and setup highly recommended
(*) We do NOT recommend using Windows XP anymore. Support has been ended from Microsoft. We recommend all users to upgrade to Windows 7 or Windows 8 as it will be the only OS supported in the future"
I'm checking out Motherboards and seemed to focussed in on an ASRock Z97 OC Formula
http://
It's not that he needs any overclocking but rather the overall robustness with a 5 year warranty has caught my eye. Also the Conformal Coating is a definite plus but less so. The Nauticomp / Dell GX620M displayed no signs of any serious corrosion when I took it apart today even though it has 2 fans running all the time in a push / pull configuration across the copper CPU Heatsink. (It's an Intel Pentium D so it always runs hot compared to today's processors.) I wish the ASRock Z97 OC Formula came in a smaller form factor as I'd like to keep the Case small enough to fit into the same spot in the Helm Consul. But if a bigger Case is need for maximum reliability than so be it.
Please chime in if you can add to the discussion. Adding extra cost will not really impact the build if we can justify the expense.
Thanks for the assist.
Regards,
Jim
◾Video Board:
◾DVD reader
http://
Regards,
Jim
