Marvell 88W8335 802 11b/g Wireless Network Adapter PCI
Do an online search - If no success,
If you go in device manager, (for whichever device you need driver for)
Right click properties, go in details for the device driver.
You will see a code like per example VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in this case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com.
Enter the two codes and you should get the name of your hardware. From there you can search for a driver download for your hardware.
Hi I was wondering if you can help me with this I have a Blast wif pci marvell 88w8335 802 11b wireless network adapter pci but I have the driver for windows 8, all I see are for xp please send me the driver for windows 8 mi Blast is marvell 88w8335 802 11b wireless network adapter pci
