Ok- Lemme give the overview:
A few weeks ago my comp was running like a pro, then decided to crap out on me (AMD finally burnt- no clue how)
I decided it would be a great time to upgrade from my AMD 1800+, 2x 256 2100 ddr, to something much more modern.
I went to Fry's and picked up:
P4, 3.2 ghz processor (478)
2x 512 3200 ddr (more on this later)
MSI PT880 NEO mobo.
After installing, I discovered I'd have to upgrade my power source to get it working and did so.
Then the problems began:
Constant crashes from every 5 mins to every hour in EQ2 and WoW. Random restarts (once even with restarting on errors off in win XP), BSOD, constant crashes in game to desktop..ect.
I decided I'd start troubleshooting and did the most logical thing: I reformatted to start.
So I reformatted and hoped things would get better. Nope. Same thing.
So I tried onboard sound instead of my SB Audigy MP3+. Nope.
So I tried different bios settings I could figure out (MSI has some wacky bios settings....) nope.
At this point, I tried some memory tests. In memtest86 I got these errors:
Error 1:
Test: LRAND
Cache: on
Address: 333c704c
Expected: 5b2197e7
Actual: 5b197e7
Errors 2,3,4:
Test: ERAND
Cache: on
Addresses: 1177c64c 31db72cc 1569c04c
Expected: 3260a42b bbdfd25b 79bc0492
Actual: 3260a40b bbddd25b 79bc0412
So I figured it might be my memory. I am currently using Patriot 2x 512 3200 ddr (which I was told was Duel ddr, and appears to be extreme performance ddr.) I tried them in all combos of dimms, one at a time, ect.
Still crashing.
I even get some errors on starting up windows (windows has recovered from a fatal error in win32k.sys... ect.)
Other errors include: IRQ_NOT_LESS_OR_EQUAL, errors ot afd.sys... Memory read errors.... I can't pinpoint it.
I am up to date on all my soundcard and vid drivers, as with all windows updates. I have no virus's or spyware on my comp. I cannot update bios for some odd reason, as when I go through my startup disk to get to the A: prompt, I cannot access the C:, and have NO idea why, so I can't flash the new bios on. (It's definately C
So here's the thing:
What's wrong with my comp? Is the memory just bad memory? I have a lifetime warranty on it, and I WAS misled in buying it- Should I just get it replaced, or return it and buy a better brand (it's past 15 days...)(Kingston?)
Should I get another board? Should I reformat again?
I care about one thing: Stability. I don't want to crash. My old system never crashed. I don't need blazing graphics, just something that works at a good speed, and doesn't crash.
Could it be the CPU? It doesn't seem to be a CPU cooling issue, as I have a great case and the fan on the CPU is working perfectly.
Thank you all for looking at this, I'm at my wit's end.
MSI PT880 NEO mobo.
Error 1:
Test: LRAND
Cache: on
Address: 333c704c
Expected: 5b2197e7
Actual: 5b197e7
Errors 2,3,4:
Test: ERAND
Cache: on
Still crashing.
