Massive fps problems in CS:GO [6600k gtx 1070 gaming x]
Moshflipp
27
Hello everyone,
since I got my new rig: 6600k, msi gtx 1070 gaming x, 16gb 3200mhz ram
I got problems with my fps in cs:go. With fps_max 0 (no fps cap) I get on nuke not even 200 fps, mostly dropping under 130 when around enemies. Same on the "old" maps. only around 200-250 fps and dropping massive when getting near other players. I should have at least 300+ stable fps. Ich already checked nvidia settings etc. and dont know what to do. GPU/CPU usage is not a problem. Got max 60-70% usage on CPU and max 50-60% on GPU.
*edit: on overpass with medium graphic settings im mostly atound 90-130 fps. Sometimes up to 220 but only for like 2-3 secs.
I hope someone can help me
CPU Temp around 35-45° and GPU max 60°.
Yes I saw many posts about that but no solution :/ I thought I give it a try and post it again...
On dust 2 in deathmatch I have mostly around 350-450 fps but still heavy drops to around 180. On Mirage, Overpass, Nuke I have max 200-250 fps and very often fps drops to around 120 sometimes even to under 100 fps. If theres no soultion and nobody knows wtf is going on, I will delete this post. Sorry to annoy you then.
*edit: CPU load around 60-70% GPU load max 40-45%
