massive Gateway GT5654 gaming upgrade need help
Travid
13
i am new to building and upgrading computers and i have an old Gateway GT5654 computer i want to upgrade and make into a gaming computer and i need some help with parts.
i currently have this list of parts
Seagate ST310005N1A1AS-RK 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Retail kit
GIGABYTE GA-970A-D3P AM3+/AM3 AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
SeaSonic SS-400ET Bronze 400W ATX12V V2.2/EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply - OEM
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
AMD FX-6300 Vishera 6-Core 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W Desktop Processor FD6300WMHKBOX
GIGABYTE GV-R725XOC-2GI Radeon R7 250X 2GB 128-Bit GDDR5 PCI Express 3.0 HDCP Ready Video Card
i want to know if i dont need to get a new motherboard or if there are any other parts i don't need or that wont work for this setup
The only thing missing is a case then it's a complete new build. Don't you want to do that? Better cooling more room for components and the motherboard will fit(the GT5654 only takes mATX motherboard, i just looked at images though).
im probably going to buy a new case and im comparing the difference between the seagate Seagate ST310005N1A1AS-RK 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Retail awkit and the Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive whats the difference.
and are you saying i don't need a new motherboard
and do you know what tower i should buy im on a budget
No no, get an new motherboard. Your current motherboard won't fit the FX-6300.
A good budget case i would recommend is the Cooler Master HAF 912, can't beat this for it's price and cooling.
About those hard drives, well i'm not a harddrive expert, but i am using the Seagate Barracuda ST1000DM003 1TB for over a year now, and it performs great. Solid HDD and it's cheaper than the other one you mentioned.
i have no budget but the problem is this is going to be funded mainly by my parents not me so i have to keep it as cheap as possible and they wouldn't react well to the sound of a $50 even $35 case
cool thanks i was looking at a Sentey® Bxp600-ps Pc Power Supply / 120 Mm Red Bearing Fan / ATX 2.2 / 115-230 V / Single Rail 12v / 1xpci-e+4xmolex+4sata / 78% Efficiency / Over Power Protection / Over Voltage Protection / Short Circuit Protection / Under Voltage Protection / Black Chassis Color / Red Fan power supply on amazon because it is only $30 do you know if it is good
and can you recommend a good cheap dvd
can cd/dvd burner's also play cd's because i found this ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM and i cant tell
