[SOLVED] Masterview CS1782 mac and wireless mouse
suell64
Hello,
I am using a MasterView 1782 device with both my mac and PC. I am also using a Logitech Wave wireless keyboard and mouse plugged into the masterview via the mkini receiver. The mouse and keyboard have quit working on the mac while still working on the pc.
What can I do to get it working again on the mac.
I would start checking if you can select/turn-on your Logitech hardware under the Mouse and Keyboard area of your System Preferences.
Also try downloading the latest Macintosh driver software for your Logitech devices:
http://www.logitech.com/en-us/support-downloads?modelsearch=yes&modelNumber=wave
After installing the driver, look under Other at the lower part of your System Preferences to check if the software gave you additional configuration options.
