Matrix 280x eyefinity problem
DavidMack
8
Hi,
I have a ASUS matrix r9 280x which has 4 display ports and 2 DVIs.
I have 3 monitors with HDMI slots in the back.
I am using two DVI to HDMI converters for two monitors, and a Display port to HDMI converter for the third.
My problem is I can only get two monitors active at any one time.
Please help!!!
Thanks, David.
An Active DisplayPort to HDMI converter may work, but is not specified by AMD or ASUS as a cable that would work. You probably have a passive adapter, which essentially carries a HDMI Video signal from the GPUs DisplayPort to your monitors HDMI port.
Okay, well I'm kinda F***ed as the monitors don't have DVI. I saw a youtube vid. of these monitors (AOC E2461FWH) running in eyefinity x3, is it possible that set-up had a gpu which had no DPs?
Sorry to be a pain, but I don't understand why an active DP to HDMI wouldn't work?
Ok bud, thanks for all your help :)
