MATX Build for LAN/Tournaments
nsiders09
19
Approximate Purchase Date: Christmas
Budget Range: $1500 (Before Shipping/Rebates)
System Usage: Gaming/Internet/Movies
Are you buying a monitor: No
Parts to Upgrade: Everything except mouse/keyboard/headset
Do you need to buy OS: Yes
Parts Preferences: None
Overclocking: Yes
SLI or Crossfire: No
Your Monitor Resolution: 1920x1080
Additional Comments: I would like a gaming computer that I can use for LAN Parties/Tournaments that can play any games on max setting with zero lag.
Why Are You Upgrading: Because I am currently using a computer that I have been using since January 30, 2000!
$20 ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
$70 NZXT Crafted Series Vulcan Black Steel / Plastic Gaming mATX Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146065
$70 Western Digital WD Black WD5003AZEX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236345
$300 HIS IceQ H795Q3G2M Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161407
$90 SeaSonic M12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095
$40 Mushkin Enhanced Blackline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226099
$220 Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
$100 Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
$90 ASRock Z77M LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157325
Subtotal: $999.91 + shipping
You can get Win 8 or Win 7, I prefer 7
For $100 more you can get a h100 water cooler with a double radiator that could mount on the top of the case, the processor is K series so you can overclock it in future
nsiders09
19
kk changing the budget to $1,500 that's the most I can put towards a new computer.
A good list from alvine.
I like the NZXT case for lan party.
If you live near a microcenter, you can pick up a 2500K for $160, or a 3570K for $170.
Since you already presumably have a previous OS, buy a Windows 8 pro upgrade kit for $70.
I am not a fan of 8 though.
A 7950 needs only a quality 500w psu.
The Corsair builder cx 600w is $50 after rebate:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
Spend $30 or so for a cm hyper212 cooler.
Consider buying a SSD instead of a hard drive.
120gb will hold the os and a handful of games. You can add a hard drive later if need be.
If you can manage 180gb or 240gb, you may never need a hard drive at all.
Samsung 830 or Intel 330 would be my pick for reliability.
Expect to pay <$1 per gb. Look for sales.
With a revised budget, let me suggest a ITX based option.
Look at the lian li PC-TU200B ITX case. It is clearly designed for Lan party transportation.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112348
It is a bit pricey @$170, but there is the same case, the PC=Q08 sans the carrying handle for $ 110.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112265
The cases are small, and, because they are aluminum, they do not weigh as much.
I have one in red which is a stunning color. No longer produced, but might be available on e-bay.
There is limited height for a cpu cooler. About 110mm, so a low profile cooler is in order.
The 140mm intake fan provides plenty of cool air for the cpu and gpu.
You will need a downdraft type oem cooler like the Noctua NH-L12, but the stock intel cooler will do the job sufficiently well.
It will get noisy though. Some have installed all-in one liquid coolers with the radiators occupyint the top 120mm exit spot.
This might be reasonable, but I would try the stock cooler first.
For good cooling graphics cards in any case, I like the direct exhaust type coolers better.
The HIS linked looks good, and EVGA makes a nice GTX670 FTW.
Look at the ASRock Z77E-ITX motherboard for $150.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157312
@bigcyco1:
Nice.. A picture is worth a thousand words.
I like the ability to use a full sized cpu cooler.
That comes at the price of a slightly larger box than the Lian li Q08.
I think I would use a 180mm fan like the silverstone air penetrator for the front.
In my Silverstone TJ-08E, it provides all the cooling needed, even undervolted.
Good idea thanks ;)
nsiders09
19
This is what I plan on building let me know what you guys think! Btw I already have a Optical Drive and a Graphics Card.
CPU: i5-3570K $170 @Micro Center
MOBO: ASUS Maximus V Gene $200 @Newegg
RAM: G.SKILL Ripjaws X 8GB 1600Mhz $40 @Newegg
CASE: SilverStone TJ08B-E $100 @Newegg
HDD: SAMSUNG Spinpoint F3 1TB $85 @Newegg
SSD: SAMSUNG 830 128GB $110 @Newegg
PSU: Rosewill CAPSTONE 550M $80 @Newegg
OS: Windows 7 Home Premium SP1 64-bit $100 @Newegg
Total: $885
nsiders09
19
Really like the Prodigy so im going with this instead :) I have a EVGA GTX670 FTW as my gfx card!
MOBO: ASUS P8Z77-I Deluxe $185 @Newegg
HSF: Cooler Master Hyper 212 Evo $30
RAM: G.SKILL Ares 8GB 1600Mhz $38 @Newegg
CASE: BitFenix Prodigy $90 @Newegg
SSD: SAMSUNG 830 256GB $200 @Newegg
Total: $803
Looks great remember like i mentioned you're going to want to buy some good case fans the ones it comes with are decent.It gets toasty trust me lol.I add a 200mm to the front and 140mm to the rear then i took the two stock 120 mm case comes with and added them to the top of case.
