Hello,
Bought my new PC parts, assembled everything, but I'm having a hard time routing all the cables efficiently (the case won't even close properly on the left side, lol) I don't even have a GPU, yet, which will be 287mm in length which isn't a problem, since my case supports up to 400mm, when the upper HDD cage is removed. But the problem will be when I actually do get the GPU, and all the cables will be in it's way.
Any guides you can give me, to better cable manage my PC? Sucks that my PSU's cables aren't flat, even though they are modular.
The case that I'm using is Fractal Design ARC Mini R2
Mobo - Asus Gryphon
PSU - OCZ TX 650W fully modular (Bronze).
P.S. - It's my first PC build, so it's probably why I suck at this.
Mobo - Asus Gryphon
