Build Advice mATX/ITX system refresh possible under $1000?
txgowan
13
I'm looking for recommendations for a system refresh. The budget is under $1000, but the less, the better, obviously.
This is my current hardware setup:
https://pcpartpicker.com/user/prasekd/saved/crGbK8
I want to reuse the SSDs, video card, and power supply if I can. I also have a Corsair H100i PRO AIO that I bought a while back and would like to use.
I'm considering a Ryzen 5/7/9 3000 series CPU. I'd like 2.5Gbit Ethernet and Bluetooth. 32 GB of RAM will be ideal. I'm contemplating either adding or replacing the SSDs with M.2 drives but I'm unsure of the bandwidth constraints. I understand it's likely I can't fit everything I want into this package.
I don't have a lot of space (15"x18") for the case, so I'm leaning towards mATX or ITX form factor. As far as aesthetics, I'm not super-interested in any RGB or color scheme. I wouldn't mind something cool (please, no red, I'm colorblind and it'd be wasted on me), but my PC sits to the left of me, so I think I'd need an inverted case otherwise all the fancy colors will be facing the wall.
Any questions, feel free to ask. I appreciate any and all suggestions.
SteveRX4
Notable
BANNED
Sep 29, 2020
1,477
135
890
20
CPU: Intel Core i7-4790K 4 GHz Quad-Core Processor
CPU Cooler: Intel E97379-001 CPU Cooler ($8.25 @ Amazon)
Motherboard: Gigabyte GA-Z97X-UD5H ATX LGA1150 Motherboard
Memory: Crucial Ballistix Sport 8 GB (1 x 8 GB) DDR3-1600 CL9 Memory ($64.98 @ Amazon) x4
Storage: Samsung 850 EVO-Series 250 GB 2.5" Solid State Drive ($107.99 @ Adorama)
Storage: Samsung 850 Pro Series 512 GB 2.5" Solid State Drive ($260.98 @ Amazon)
Storage: Western Digital Caviar Black 2 TB 3.5" 7200RPM Internal Hard Drive
Storage: Hitachi Deskstar 7K4000 4 TB 3.5" 7200RPM Internal Hard Drive
Storage: Toshiba 5 TB 3.5" 7200RPM Internal Hard Drive ($185.00 @ Amazon)
Video Card: MSI GeForce RTX 2060 SUPER 8 GB VENTUS OC Video Card
Case: Antec P100 ATX Mid Tower Case
Power Supply: EVGA SuperNOVA 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Optical Drive: LG WH12LS39 Blu-Ray/DVD/CD Writer
Monitor: Asus VG248QE 24.0" 1920x1080 144 Hz Monitor
Monitor: Asus VS248HR 24.0" 1920x1080 60 Hz Monitor
Keyboard: Razer BlackWidow Ultimate Wired Gaming Keyboard ($199.99 @ Amazon)
Mouse: Razer DeathAdder Elite Wired Optical Mouse ($67.00 @ Amazon)
Total: $1350.11
SteveRX4
Notable
BANNED
Sep 29, 2020
1,477
135
890
20
Basically, the upgrade would be CPU and/or GPU. Even though your CPU is old, I don't think you'd run it too hard with 2 x 1080p monitors.
It would also be a hard task to ugrade CPU/Mobo/RAM plus GPU under $1000.
I'd probably tend to upgrade your CPU/Mobo/RAM as it's getting out of date.
So do you prefer to upgrade your cpu/mob/ram or your GPU?
If you want to upgrade CPU/mobo/ram - do you want to go Intel or AMD?
txgowan
13
I don't have a problem with my current video card. It's only a year old to me and I don't think I'd get much for it considering the 3000 series are coming out.
As I said in my original post, I'm leaning toward a Ryzen 5/7/9 3000 series CPU. I'd like 2.5Gbit Ethernet and Bluetooth. 32 GB of RAM will be ideal. I think I want to keep at least the two Samsung PRO SSDs and add an M.2. I read elsewhere that I might be stressing the available bandwidth between GPU, M.2, SSDs and general bridge overhead. Do you know if that's the case?
I also recently rearranged my office and now my PC is on my left. The surface that my PC is resting on is too small for this big ATX case, so I'm also thinking about doing something mATX or ITX. The space is 18" deep and 16" wide.
Thanks!
ragnarok0274
Great
Sep 12, 2020
147
8
95
Wait until Ryzen 5000 comes out to get a Ryzen 3000 chip. They will be much cheaper.
Other than that, I don't know.
I only get ASUS motherboards.
