K Konstantinos Koutse Reputable Jan 10, 2015 649 0 4,990 Apr 13, 2016 #1 So intel says max temp is 72.72 degrees celcius so that means that if my cpu reaches 72 degrees it will be damaged ?
SPgamer007 Honorable Nov 17, 2013 1,630 0 12,460 Apr 13, 2016 #2 No,it's max "safe" temperature, once the CPU reaches above 90c it will throttle itself to cool down,so no damage easily. Upvote 0 Downvote
N niko3688 Distinguished Mar 29, 2015 140 0 18,715 Apr 13, 2016 #3 Not necessary damaged when it hits 72, but it could be throttling at the temp. If you're CPU it hitting that temp, go for a new cooler, or apply new thermal paste Upvote 0 Downvote
K Konstantinos Koutse Reputable Jan 10, 2015 649 0 4,990 Apr 13, 2016 #4 im reaching 64-65 degrees at 78-80% load on my i5 4690 thats why im afraid btw im using stock cooler Upvote 0 Downvote
Alan Caldwell Distinguished Jul 24, 2014 3,828 0 18,960 Apr 13, 2016 Solution #5 Get a better cooler, temps till 80 is safe. Upvote 0 Downvote Solution
coolcole01 Splendid Oct 24, 2013 4,280 4 25,315 Apr 13, 2016 #6 your fine just keep track of it and if it doesn't seem to be moving up your good to go but if your worried you can always get a better cooler. Upvote 0 Downvote
Alan Caldwell Distinguished Jul 24, 2014 3,828 0 18,960 Apr 13, 2016 #7 Get a Cooler Master Hyper 212X. Upvote 0 Downvote
