L Leonardo_27 Prominent May 2, 2017 1 0 510 May 2, 2017 #1 So i put my cores um to 2 and my memory to max and i restarted my pc as normal so the new settings work and then my pc would not start and wen in blue screen and then i was so slow that i cant open"msconfig" to fix what an i do
Solution M M marko55 May 3, 2017 Check your motherboard's manual for how to clear your CMOS. This will reset your BIOS back to default and you can start over.
M marko55 Honorable Nov 29, 2015 800 0 11,660 May 3, 2017 Solution #2 Check your motherboard's manual for how to clear your CMOS. This will reset your BIOS back to default and you can start over. Upvote 0 Downvote Solution
