Max o/c for 9800 pro?
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hi!
I would to o/c my 9800pro ATI card, but do not want to scrap it... As of
yet, I raised core and memory up to 20Mhz, but was too scared to go further.
As anyone has suggestion how fare I could go without having problems?
Many thanks!
Daniel
www.dromadaire.com/cimetiere/english
"cimetière" <cimetiere@moncanoe.comsapmmmmmmm> wrote in message
news:h7Ric.1518$Tu2.114917@weber.videotron.net...
> Hi!
further.
> Many thanks!
> Daniel
I ran mine at 432/712 to benchmark it, I usally just run at stock settings
since it is plenty fast.
Download a program called ATI Tool from majorgeeks.com and it will set up
the optimum overclock settings for you.
GeeZer
cimetière <cimetiere@moncanoe.comsapmmmmmmm> nie ma racji, ale pisze, ¿e:
412/665 MHz should be good and quite safe. These are R9800 XT clocks. 😀
> Many thanks!
maniac
maniac(at)chello.pl
"You're the sun and the moon to me."
(c) Owen Crawford, Taken
make sure you have above average cooling solution before commencing
with an OC.
> Hi!
As of
further.
problems?
> Many thanks!
> Daniel
cimetière left a note on my windscreen which said:
> Hi!
> Many thanks!
This is from memory so I may be a little out - With the help of ATI Tool
(google for it) I was able to increase my Hercules 9800 Pro (not a
standard cooling system on this card) to 450/350 (700).
I have since set it back to standard settings. The performance gain
(unless you're into counting 3DMark numbers) didn't realy seem worth it.
Stoneskin
[Insert sig text here]
