Max # of PCI Express Lanes
Kalibek
Commendable
Jun 26, 2016
39
So I just built a new PC with i5 6600k and obviously I have GPU - AMD RX480 which is 3.0x16 and one m.2 nvme ssd is coming my way, which is also PCI Express Gen3 x4, and i5 supports only 16 lanes, does it mean I already maxed it out and will not be able to use m.2 ssd on its full power?
http://www.tomshardware.com/forum/id-2604000/h170-z170-motherboards.html
H170 does *not* allow you to split the CPU PCIe lanes. So on H170 boards you'll get 1xPCIe 3.0 x16, and any further PCIe slots will be using lanes from chipset which are limited to a maximum of x4 lanes. That means NO SLI. Although CFX will technically work, it's not ideal and with high end hardware not a good idea.
Z170 on the other hand allows boards to split CPU PCIe lanes, providing two x8 slots, enabling multi-GPU options. To be clear, not all Z170 boards will actually implement this, but the fact is they can, whereas H170 boards cannot.
H170 boards can still offer great value for money as long as they're recognised as single-GPU only boards. Sorry again...
thanks,
I have Gigabyte Z170n gaming 5 mini itx mobo
Expansion Slots
1 x PCI Express x16 slot, running at x16
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
Storage Interface
1 x M.2 Socket 3 connector on the back of the motherboard (Socket 3, M key, type 2260/2280 SATA & PCIe x4/x2/x1 SSD support)
H170 boards can still offer great value for money as long as they're recognised as single-GPU only boards. Sorry again for reviving this thread, just felt it was an important bit of info for people trying to get their heads around these sometimes confusing chipset implementations.
