Question Max out fan speed
Jimcuchim
BANNED
Feb 25, 2019
81
Is there anyway to max out my fan speed at all time(to reduce throttling). At the moment I don't care about the noise at all. I have a:
Lenovo 320s-131kb
i5-8250u
No graphic card
4GB RAM
I really need my CPU to not throttle to record game plays.
Thank you alot
So is there any way to stop my cpu from slowing down and lagging my recoriding?
You can try and raise the laptop off a flat surface about an inch so that it has more airflow around the bottom. Outside of that the only way would involve Voiding you Warranty by opening up the laptop and replacing the thermal grease on the CPU heat sink with higher paste or going for a liquid metal thermal compound.
