Max overclock gtx 950 2GB
Brian_51
55
Hello all,
I couldnt find a max overclock for my gtx 950 2Gb on google. Does any1 know what the max stable overclock is for the nvidia geforce gtx 950 2GB?
I have this currently and its running stable at 65ºC on heavy load:
Thanks in advance!
That's not how it's looked at, every card is different and overclocked differently, some can go higher without changing the voltage, some can't.
You need to find out a stable overclock of your GPU by yourself at the most, there are tons of GPU overclocking guides, just some advises are to don't touch the voltage and go easy on core and memory clocks, keep an eye out for artifacts while benching the overclocked card.
Thanks i will check some guides!
Good, but don't forget to thank geofelt as well. :)
Thanks. I didnt know that. I thought it whas the same for all gtx 950's
