Max Payne 3 8x MSAA framerate
Elax
9
Is it normal to have massive fps drops in some areas while maxed out at x8 MSAA while having smooth 60fps no drops on x4 MSAA?
my gpu handles battlefield 4 and Crysis 4 maxed out at 60fps, I find it odd that Max Payne 3 cant run maxed out on my rig. Are any of you having this issue?
specs
Intel i7-2600 @ 3.40ghz
8gb Ram
Zotac GTX 770 AMP!
650W PSU
1440x900 monitor
Crysis 4 is not out yet...😉 Anyway,if your card is the 2GB version,it is maybe pushing the card too much for VRAM for a rock solid 60fps.I have a 3GB R9 280X and I too get problems and dips with 8xMSAA,while dropping to 4xMSAA works just fine.Not sure,but NVIDIA recommends a minimum of a 600W PSU for that card,so it could be a power issue as well. :)
