Max RAM speed compatible with FX-8350
The CPU is rated up to 1866 at 1 stick per channel or 2 sticks - some 8350's have been able to run 2133, but not all...if the 2133 you see is about the same price as 1866 - go for i, if need be can always clock down to 1866 and tighten the timings :)
Got ram to run at 2400 with 8350 fx and sabretooth 990 fx r1 & latest bios. Over clocked profile corsair vengeance 2400 at 1.65 volts, system crashed during benchmark possibly due to not optimising system volts still playing with it have settled for 4632 ghz cpu 2230s ram for now only got cpu today. Custom watercooled using feser fluids about 1.2 litres in loop using 240 twin fan rad and d5 pwm pump topped off with dvd style drivebay clear reservoir, acid green coolant looks cool
Cpu z ram timings state
Cl 11
Ras to cas 13
Ras pre charge 13
Cycle time 31
Bank cycle 46
16 gb corsair Vengeance pro 2400 stable 2400mhz at 4.6 gig cpu speed around 40 celsius upto 52 after lengthy gaming
