A Ale415 Commendable Mar 7, 2016 3 0 1,510 Mar 7, 2016 #1 Wondering whats the max ram speed supported in my Dell Optiplex 780 so I can upgrade it and use for a (hopefully) later build CPU; C2Q Q6600 MOBO; Dell e93839 ga0402 Current RAM; 2x2gb 1066 mhz ( hmt125u6bfr8c-g7 no aa-c 1006 )
Solution Ubrales Mar 7, 2016 Up to 4 DIMM slots (2 for USFF); Non-ECC dual-channel 1600MHz DDR3 SDRAM, up to 16GB. http://www.dell.com/us/business/p/optiplex-7010/pd
Ubrales Polypheme Dec 3, 2009 13,240 11 61,465 Mar 7, 2016 Solution #2 Up to 4 DIMM slots (2 for USFF); Non-ECC dual-channel 1600MHz DDR3 SDRAM, up to 16GB. http://www.dell.com/us/business/p/optiplex-7010/pd Upvote 0 Downvote Solution
A Ale415 Commendable Mar 7, 2016 3 0 1,510 Mar 7, 2016 #3 Ubrales : Up to 4 DIMM slots (2 for USFF); Non-ECC dual-channel 1600MHz DDR3 SDRAM, up to 16GB. http://www.dell.com/us/business/p/optiplex-7010/pd So this would be compatible w/both mobo & cpu ? thanks btw! http://www.newegg.com/Product/Product.aspx?Item=N82E16820233180 Upvote 0 Downvote
Ubrales Polypheme Dec 3, 2009 13,240 11 61,465 Mar 8, 2016 #4 Ale415 : Ubrales : Up to 4 DIMM slots (2 for USFF); Non-ECC dual-channel 1600MHz DDR3 SDRAM, up to 16GB. http://www.dell.com/us/business/p/optiplex-7010/pd So this would be compatible w/both mobo & cpu ? thanks btw! http://www.newegg.com/Product/Product.aspx?Item=N82E16820233180 Yes they would work! They are 4 GB memory modules, DDR3, and 1600 MHz speed. The max for your computer and motherboard. These are great memory modules and I have the same but in 8 GBs for a total of 32 GBs on my motherboard (different motherboard) . Works great! Upvote 0 Downvote
A Ale415 Commendable Mar 7, 2016 3 0 1,510 Mar 10, 2016 #5 Alright thank you so much! Upvote 0 Downvote
