For my invida card it says 2560 x 1600 (DL-DVI). I need to know does this mean that I can only use this resolution if I use a DVI cable or can I use a HDMI to get it. And also what are the difference between the two. Thanks also here is the card if anyone needs to see it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130794
