What is the maximun temperature CPU can withstand for a long period of time without fear of burning out?
Mione is currently (OC'd) 56 degrees full load...is that too much?
You should be fine with those temps under full load.However I would not let it get over 65 celcius.
What you could also do is, in CoreTemp, click Options -> Settings. Then uncheck "Enable Logging".
That way, it will run in the background and it wont continuously log your temps in a log file (which can get rather large). You can then just hover your mouse over the CoreTemp system tray icon to quickly chck your temps.
Yes, that is safe. But its still a bit high. When OC'ing your components, you need to ensure that you have adequate cooling.
Dont want to get too technical, but heat is bad for your cpu, the lower you can get your temps, the better...
