Jonatron5,
As with the majority of Intel processors, although "Throttle" temperature or "Tj Max" for the 9900K is 100°C, it does
not mean that it's OK to run it anywhere near that hot. The consensus among
Intel's Engineers, well informed and highly experienced reviewers, system builders and expert overclockers, is that it's prudent to observe a reasonable thermal margin below Throttle temperature for ultimate stability, performance and longevity.
Here's the nominal operating range for Core temperature:
Core temperatures above 85°C are not recommended.
Core temperatures below 80°C are ideal.
Core temperatures increase and decrease with ambient temperature, for which the International Standard for "normal" room temperature is 22°C or 72°F.
• Overclocking is always limited by two factors; voltage and temperature.
Contrary to
logikabg2004's "easiest overclock" suggestion, it's
not recommended to use “Auto” BIOS settings, motherboard features or software utilities, as significantly more Vcore than necessary is applied to maintain stability, which needlessly increases Power and heat. My esteemed and highly experienced colleague,
Darkbreeze, knows this all too well, and explains it in great detail in his excellent "
CPU overclocking guide and tutorial" which is recommended reading.
Moreover,
Rodrigodrt's suggestions have some flaws. 1.35 Vcore for 22nm processors as well as 1.45 Vcore for 14nm processors are both above the "safe" level on the degradation curves. Additionally, 1.45 Vcore on an 8 Core 16 Thread Intel CPU, even if it's delidded, would be nearly impossible to cool at 100% workload by big Air, 280 / 360 AIO or anything less than a seriously capable custom loop.
Further, to approach overclocking, stability and thermal testing from the "top down" is the "completion backwards" principle. We all instead know that the correct approach is from the "bottom up", which is to slowly and incrementally increase frequency and voltage, without attempting to haphazardly circumvent the process and potentially risk damaging your hard-earned hardware for the sake of immediate gratification.
Each Microarchitecture has a “Maximum Recommended Vcore”. For example, it’s important to point out that 22 nanometer 3rd and 4th Generation processors will
not tolerate the higher Core voltages of other Microarchitectures.
Here's the Maximum Recommended Vcore per Microarchitecture from 14 to 65 nanometers since 2006:
We know that over time, excessive voltage and heat damages electronics, so when using manual Vcore settings in BIOS, excessive Core voltage and Core temperature can cause accelerated "
Electromigration". Processors have multiple layers of hundreds of millions of microscopic
nanometer scale components. Electromigration erodes fragile circuit pathways and transistor junctions which results in the
degradation of overclock stability, and thus performance.
Although your initial overclock may be stable, degradation doesn't appear until later, when increasingly frequent blue-screen crashes indicate a progressive loss of stability. The more excessive the levels of voltage and heat and the longer they're sustained determines how long until transistor degradation destabilizes your overclock. Decreasing overclock and Vcore may temporarily restore stability and slow the rate of degradation.
Extreme overvolting can cause degradation in minutes, but a sensible overclock remains stable for years.
Each Microarchitecture also has a "
Degradation Curve". As a rule, CPUs are more susceptible to electromigration and degradation with each Die-shrink. However, the exception to the rule is Intel's 14 nanometer Microarchitecture, where advances in
FinFET transistor technology have improved voltage tolerance.
Here's how the Degradation Curves correspond to Maximum Recommended Vcore for 22 nanometer 3rd and 4th Generation, which differs from 14 nanometer 5th through 10th Generation:
Degradation Curves are relative to the term “
Vt (Voltage threshold) Shift” which is expressed in millivolts (mv). Users can not monitor Vt Shift. With respect to overclocking and overvolting, Vt Shift basically represents the potential for
permanent loss of normal transistor performance. Excessively high Core voltage drives excessively high Power consumption and Core temperatures, all of which contribute to gradual Vt Shift over time. Core voltages that impose high Vt Shift values are
not recommended.
To achieve the highest overclock, keep in mind that for your final 100 MHz increase, a corresponding increase in Core voltage of about 50 millivolts (0.050) is needed to maintain stability. If 65 millivolts (0.065) or more is needed for the next stable 100 MHz increase, it means you're attempting to overclock your processor beyond its capability.
With high-end cooling you might reach your Maximum Recommended Vcore limit before you reach the ideal Core temperature limit at
80°C. With low-end cooling you’ll reach
80°C before your Vcore limit. Regardless, whichever overclocking limit you reach first is where you should stop. Thermal testing is explained in Sections 10 through 12.
Remember to keep overclocking in perspective. For example, the difference between 4.5 and 4.6 GHz is less than 2.3%, which has no noticeable impact on overall system performance. It simply isn’t worth pushing your processor beyond recommended Core voltage and Core temperature limits just to squeeze out another 100 MHz.
CT
