Max settings
da rulz
23
People, can you tell me which card(nvidia or ati) is just enough to play all games at MAX settings, at resolutions 1080p and 1600 x 900??????(at 60 fps)
You'll never get constant 60 in modern demanding games unless you're running a high-end card and set graphics to low. (Even with that, I still can't guarantee it)
Just to make things easier, this would be the card I recommend based on their price and performance
$380-400
AMD Radeon HD7970
Nvidia GeForce GTX 670
$300-320
AMD Radeon HD7950
$230-250
AMD Radeon HD7870
Nvidia GeForce GTX 660
$200-220
AMD Radeon HD7850 2GB
$165-180
AMD Radeon HD7850 1GB
$145
Nvidia GeForce GTX 650ti
$120-135
AMD Radeon HD7770
$95-110
AMD Radeon HD7750
The GTX650 (non-ti) performs around the HD7750, sometimes it wins, sometimes it loses, sometimes they're both similar. However, I gave recommendation to the HD7750 because it's usually less expensive albeit slightly.
wha'abt far cry 3(just ordered) could i play it at high settings, res-1600 x 900 and max textures? anyways, thanks for your advice as i was clueless about all this
