Max stable overclock for gtx 750?
microtechsteve
43
Rough estimate of what mhz is max stable for gtx 750? I'd really like to hear from those who have overclocked a gtx 750. I'm trying to overclock my gtx 750 so I could get better fps on Rainbow Six.
Rig:
i7-4790
GA-H97-D3H
Galaxy GTX 750 1GB
I have already overclocked my gtx 750 to 250mhz on both memory and core. I get around 40c-60c depending on the game.
Impossible to tell. Every 750 is different. You have to keep increasing it till it starts showing artifacts (weird lines and colors), then back of by 15-30MHz to make it stable. Unigine Heaven or Valley is popular for testing an overclock on the go.
I remember mine being 220MHz+ Core and 550MHz+ memory.
Rig:
i7-4790
GA-H97-D3H
Galaxy GTX 750 1GB
A GTX 750 is wasted on that rig. You're better off upgrading it as a 750 will slow down the CPU too much. I recommend a GTX 960 (50$+ used price on ebay)/970 (75$ used price on ebay) or better. Just get one with two week or more testing period. Also...
Rig:
i7-4790
GA-H97-D3H
Galaxy GTX 750 1GB
A GTX 750 is wasted on that rig. You're better off upgrading it as a 750 will slow down the CPU too much. I recommend a GTX 960 (50$+ used price on ebay)/970 (75$ used price on ebay) or better. Just get one with two week or more testing period. Also, overclocking will give a 15% boost at best.
960 vs 750
970 vs 750
If you decide to upgrade, get the 4GB version GPU as some of them have a 2GB version. 4GB should last a while.
