Max sustained safe temperature for 4770k i7 ?
mtb_mike
I have a 4770k i7 with the stock cooler running at 90ºC on all cores. This will be a sustained load (3D rendering) for days on end. This may be too hot I'm finding out? It's in a Cooler Master Elite 120 Advanced case so cooler options are limited. Of course I can always get a larger case.
Question is, what temps should I aim for and what kind of a cooler will get me there? No over clocking (yet anyway).
Thanks from a pc building newbie.
Definitely should consider liquid cooling. I have a standard atx case that had knock-outs for mounting a radiator externally to the case. I built a custom bracket to mount it to the outside of my tower. Under heavy load with the i7 4770K at 4.6 GHz it hovers around 60 - 70 C and cools off to 25...
You are pretty close to that magical temperature where your CPU just melts (TJ MAX is 98C). I would recommend at the very least replacing your thermal grease, if not upgrading to a better cooler. It's an expensive CPU, and given the load it's under you should definitely spend a little cash to protect your investment. I'm running an i7 870 overclocked to 4GHz and my H80 waterloop keeps it under 70C when burn-testing.
Also worth noting is that while temperatures up to 90C won't fry your CPU, anything over 80C definitely shortens the expected life span.
Pretty much what I thought. I wonder if a small low profile cooler will do much to lower temps? Cooler Master makes one actually. There is only 65mm of head room in that case. Thanks.
Definitely should consider liquid cooling. I have a standard atx case that had knock-outs for mounting a radiator externally to the case. I built a custom bracket to mount it to the outside of my tower. Under heavy load with the i7 4770K at 4.6 GHz it hovers around 60 - 70 C and cools off to 25 -30 C as soon as the load is removed. Granted I spent over $200 on a custom liquid cooling kit. It does take experience to install a custom water cooling system or at least knowledge of how to terminate fittings and avoid leaks and fabrication ability if it will not fit. I try and stay away from the closed loop all in one liquid cooling systems but some are better then trying to run intense tasks on an overclocked cpu with a stock air cooler.
Too hot, Try getting a liquid cooling system like Corsair Hydro H100i, i got the same processor & H100i and im running at 4.0Ghz at max 50degrees celcius max load.
This is late coming but you need a water cooling system.
CORSAIR Hydro Series H60 (CW-9060007-WW) High Performance Water / Liquid CPU Cooler. 120mm
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181030
