If IDN stands for Indonesia, yes i'm from IDNIt's a old GPU. I can't find the specific details for your GPU.
But I found the similar GPU with 2GB version :
Based on GPU-Z, the GPU using code name "Juniper". and based on this site, the TDP for Juniper code name will be around 108W.
https://www.techpowerup.com/gpu-specs/amd-juniper.g76
BTW, are you from IDN ?
So we live in same region. Cheers.If IDN stands for Indonesia, yes i'm from IDN
Are you a member of IPCBF?So we live in the same region. Cheers.
Indonesian PC Builder Forum ? Well no. I don't know there is group like that.Are you a member of IPCBF?
Agreed, but when it comes to recommendation i don't think this forum is a good place for me as a limited budget pc builder.Indonesian PC Builder Forum ? Well no. I don't know there is group like that.
I see this forum is more specific to discuss and solved issue than IPCBF, and I rarely open my FB.
No offense.
Yeah, I agree with you. But they're not wrong, of course they will give a best recommend in terms of gaming purpose.Agreed, but when it comes to recommendation i don't think this forum is a good place for me as a limited budget pc builder.
