Max temp without damaging GeForce 8600GT GPU Card
AnthonyD98
7
What is the Max Temperature or Average temperature for this card and what should it run at when idle or when its running games?
Its at 65 now when I'm running Skype, Minecraft Bukkit Server and the program I used to check it is speecy and also my Computer is Windows Vista.
No its not Overclocked.
But when i turn it on it idles at 65 degrees celcius.
Gradually it goes up when I use more graphic demanding Programs such as Mimecraft, And you tube sometimes.
Im just a bit worried that The graphics card may burn out.
And By the way my computer has 3 fans but apparently only 2 are on. Is this Normal?
