Max Temperature AMD Phenom II x4 980 BE
You should be fine, however if you can think of a new cpu cooler as a new upgrade! I suggest the 212 EVO, its cheap and well renowned for great cooling!
Well i'm staying at about 75 (sometimes even running at 78 which is the TJunction point) on load and idling at about 40. Should I be worried and buy a new cooler? Mine is the stock one from an old Athlon 64 x2 +5000 and has 3000RPM. Above it i sticked another fan from an old computer running at 2000RPM (temperatures are lower).I have thermal paste.
