Max VGA resolution
Sagarrathee77
19
Hello,
i am having quadro k2200 gpu, i want to use it with my tv, but dont have dvi or display port connector in tv, it have hdmi(4k) ports, i am also having dvi to vga converter and vga to hdmi cable, so if i attach dvi to vga ang then vga to hdmi , what is the maximum resolution i can get?? can i use it for 4K videos?? note: tv supports 4K videos and gpu too
Why don't you just use a DVI to HDMI cable or a Display Port to HDMI? Using dual converters with two different cables when you can just get a simple cable is not a good idea. I have a DVI to HDMI cable on my computer and with a audio cable from the sound card to the TV it works just fine.
no it is still limited ti the max re of the cable tipe i beleve the max rezaloshin is 1080p but i colud be roung it also dpends on the ports the newer cable and ports an saport farle hi rez but i dont it cando 4k the hdmi alone colud but the vga will be your liitein facktor you colud bye a dvi to hdmi adaptor http://www.newegg.com/Product/Product.aspx?Item=N82E16812423080&cm_re=dvi_to_hdmi-_-12-423-080-_-Product this ia a aaptor you can also get a dispoay port to hdmi adaptor http://www.amazon.com/gofanco%C2%AE-DisplayPort-Converter-UltraHD-Display/dp/B00OSBDVF8/ref=pd_sim_147_10?ie=UTF8&dpID=41cYmRDNAML&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=05DX4BQHFZVSFCDD4YF4
