Maximum CPU Temperature Under Load
ArmoredKingyo
11
So I'm relatively new to the monitoring of system heat, and I have been heavily monitoring my temperatures. My CPU gets up to about 48 C at its highest and I was worried that was too high. When researching the maximum CPU temperatures under load of my CPU (3960x), I found this thread saying that the maximum is 91 C under load. This seems way to high to be right, doesn't it?
PMentior
69
No Those number are right. An overclocked chip will commonly run a lot hotter than 48C under load (91C might be the point where the cpu will throttle itself to prevent damage and is way too hot to run at for any length of time really). My i7-970 is clocked at 4.2 and will get up to 68C. I personally wont let my chip get over 70C as that is getting out of my comfort zone.
PMentior
69
G
Guest
Guest
your 43 degrees under max. no your not fine, your fabulous!
91C is too high for the CPU for long periods of time. Average working temps under heavy and full load are in the 60 to 70C range and they are absolutely fine. Although we all like to stay below 70 if possible.
For your rig, 48C is fine but I doubt it's under full load, try the IntelBurn test and keep your eye on the temps to see what is that max you reach.
You can download it from here.
http://downloads.guru3d.com/IntelBurnTest-v2.3-download-2047.html
Use HWMontior to keep your eye on the temps or core temp.
Download from here
http://www.cpuid.com/softwares/hwmonitor.html
http://www.alcpu.com/CoreTemp/
When the rig is idle you should get temps in the range of the ambient temps of the place you are in, plus minus 10C.
jsc
Champion
Convenional cooling, air or water, will not cool below ambient air temps.
