Maximum farm can you build per turn ?
G
Guest
Guest
Archived from groups: alt.games.vgaplanets4 (More info?)
host 193
Is it 10 per turn max like it says on Tim site ?
How can you find out what is the max farm for a planet ?
these host settings influence the farms build / turn:
A) Farms require 1000 colonists each to run them
B) New Farms Per Turn
If A is YES, then the limit you can have is your number of colos. You
can build them all in simply 1 turn or spread over several. If your #
of colos drops th efarms above th elimit will not work anymore and you
will receive log entries for those bases.
If A is NO, then there is a limit of farms you can build each turn.
default value is 10. This is absolutely independent of the # of colos
you have at any point of time.
You can check A if you press the FIG button in your client. If that is
NO then ask your host about the # of farms, if you don't see it on the
site where you are playing.
In my case it is
Farms Need 1000 Colonists: YES
Totals For Our Empire
Colonists : 2 000 000
so my population / 1000 = max number of farm
so I can have 2000 farm ?
on my hw ?
climate 52 soil 100 ( the climate I understand, you can build farm or not)
What does the soil 100 STAT do ???
I play Empire with min farm climate 45 max farm climate 65
I will receive 2000 food and 2000 $ cash per turn with 2000 farm right ?
THANKS
"Sparrow" <e.kueper@gmx.net> a écrit dans le message de news:
1114167439.219006.116900@l41g2000cwc.googlegroups.com...
In addition, if the number of farms ever gets in excess of soil rating
(Borg / Solarain Ground Chunnel and also a few ships have a device that
lowers soil ratings,) all farms in excess of soil rating are lost.
You don't need the population to build or maintiagn farms, however you
do need the population to work them.
And the same 1000 colonists running a farm can run 10 mines at the same
time.
And the soil is a limit for max farms too.
Bye-Bye JoSch.
Soil is the max possible food production of farms per turn. This kind of informations you can quiet well find in the online docs
or even in the planets help file in your planets root directory.
GFM GToeroe
"lordlancelot" <lordlancelot@Nospamthankyou.com> schrieb im Newsbeitrag news:it6ae.20554$Jg5.1113449@news20.bellglobal.com...
> In my case it is
> on my hw ?
> THANKS
I just did the latest install from tim
with latest host update, and client update
their is no doc in my planet 4 dir
Doc on tim site is not complete or up to date, how can I trust those doc ?
Soil = max food production
if I have soil 100 1000 farm I get 100 food and 1000$ right ?
"Gabor Törö" <gfm@gtoeroe.de> a écrit dans le message de news:
d4assi$656$00$1@news.t-online.com...
> GFM GToeroe
>> In my case it is
>> on my hw ?
>> not)
>> THANKS
NOTE!! Farms also allow you to produce goats, which are stategically
irreplaceble if enabled by host.
- Skies
(Just noticed it yesterday on Klingon Kommand. =)
lordlancelot wrote:
> host 193
If you would please look at the setup of the game up front (on drewhead
- since that is your game), to come up with the max number of farms
allowed to be build in one turn per base, as it is a configureable host
option. Otherwise please first of all look through the help files and
read them, most of the question you did ask you would not have asked if
you would have done that.
BTW you will receive around turn 8 a Mig Shuttle with a few credits and
high tech stuff (ie. shields) - and with that the chances for the EE
are not that bad, especially considering that you can then try to get
many prisoners with them fast (troops are better for capturing than
your battlebots would be).
If you have soil 100 you can build up to 100 farms! Each farm produce 1 food
+ 1 MC
news:RM6ae.20824$Jg5.1118077@news20.bellglobal.com...
>> GFM GToeroe
>>> In my case it is
>>> on my hw ?
>>> not)
>>> THANKS
