No. I have seen 4000mhz+ Ram run with a kaby lake cpu. The maximum officially supported by intel memory speed is 2400mhz, the JDEC standard is 2133mhz for DDR4. So non overclocking motherboards such as the intel B and H series mobo's will be limted to 2400mhz some only 2133mhz. Most motherboards will default your ram to 2133mhz until you enable XMP in the bios which sets the memory to run at its advertised speeds.
