Maximum Processor Frequency 0MHz?
box o rocks
788
18
18,985
I was checking power settings in Control Panel/Power Option/Edit Plan Settings and happened to notice that Win10 defaults to The above setting of 0 MHz. That's not right, is it? Shouldn't that be the max frequency of the CPU?
Phenom II X4 965BE
Asus M4A89TD Pro/USB3
12GB 1600 MHz DDR3
Asus RX 480 Strix
Corsair TX650M PSU
technically it is infinity. a setting of 0 allows your cpu to set the max rate instead of you hard coding it when you change the cpu out to a new one.
