[SOLVED] Maximum Ram Does not Match with Model Info
bharat_14
8
Hello
I m bit confused because I have MSI GE63 RADIER RGB 9SF which have maximum ram capacity is 64 gb
but when i check with cmd wmic command it shows only 32 gb i also check with crucial scan its also shows 32 gb only
please check the link of cmd result https://ibb.co/6tMrVHp
i m using window 10 pro 64 bit
Your laptop supports a maximum of 64GB ram.
You have 16GB installed. 2x8GB sticks.
Your laptop has 2 memory slots.
You would need to replace your existing modules with larger ones for more memory.
The crucial checker often only shows the maximum the system was shipped with or could handle at the using RAM sticks that were sold at the time, higher density modules have come along since then which means many computers can theoretically support more than at time of launch.
