Question Maximum RAM, maximum HDD capacity and a manual for Sony Vaio Model PCG-71C11M, product name VPCEL3S1E?
PeterMuellerr
105
19
4,585
I wish to upgrade RAM and a hard drive for Sony Vaio PCG-71C11M, product name VPCEL3S1E. Unfortunately, I failed to find a full manual for the laptop online, just scattered, probably unreliable information here and there. Any help on the manual? I need the maximum RAM spec (I saw 2 slots inside) and maximum hard drive capacity (2.5 inch, looks like SATAIII). The processor is AMD E-...[some number]. I don't have the laptop at my regular own disposal to look up more stuff.
Max RAM: 8GB (2 x 4GB) according to the Specs Sheet
Max HDD or SSD: 2TB (based on my own knowledge of limiting factors)
Manual -- unable to help I'm afraid.
Thanks for max 8 GB RAM.
I found a spec page for the product. It's VPCEL3S1E, hence, consider https://www.sony.co.uk/electronics/support/laptop-pc-vpc-series/vpcel3s1e/specifications, except the color is black . Do you give the same advice concerning the hard drive or would you like to change it?
