Maximum Recommended Gaming Resolution for Quadro FX-1800
Gogeto_16
Commendable
Jan 26, 2017
232
Hi guys,
Just having a little prob. My Friend has a Intel Core 2 quad Q8400,DDR2 5GB RAM and Nvidia Quadro FX-1800 (768MB) So right now he is using a LCD whose max resolution is 1024x768..So the prob. is that I have a spare LCD whose MAX RES is 1280x1024 and my friend want that LCD so playing games at 1280x1024 is not a big deal but for Quadro FX-1800 is this a good decision I mean you guys can understand... ... ...
Bro I know it's old old and very i'm not asking for suggestions or what ever you are talking about... but there should be a Maximum Recommended Gaming Resolution for Quadro FX-1800
The "Maximum Recommended Gaming Resolution" is going to depend on YOUR tolerance for slowness. Some people on this board won't accept less than 100FPS. Your tolerance for any FPS dips is going to be different. The specific title is going to make a difference. I don't believe there is a magic max resolution. Just test it. That is really the best answer.
Umm 40FPS are average isn't it?
The Quadro FX 1800 is somewhere between a GeForce 9600 GS and 9600 GSO in performance and specs. In terms of period correct titles it should have mid-range performance on 2009 and earlier games. I would expect it to run well on those titles at 1280x1024. On newer games it should be taken on a case by case basis.
yep that's what i'm thinking but at least quadro FX 1800 can run 2011 games on medium graphics on 1280x1024 resolution right?
Well suggest me some GPU's I'll tell my Friend about it :) How about some ATI GPU's
