K keeezual Reputable Dec 3, 2015 47 0 4,540 Aug 3, 2017 #1 Hello, i just got a new tv and i wanted to use it as a monitor over vga cable. Its native res is fullhd but the max i can get is 1600x1200. Im using amd 17.7.2 drivers and an r9 380. The result is that everything just looks smudgy and awful
rgd1101 Don't Moderator Nov 7, 2011 74,864 4,245 176,290 Aug 3, 2017 #2 if is only 1080p why are you setting to 1600x1200? Upvote 0 Downvote
159159159 Commendable Jul 25, 2016 58 0 1,640 Aug 3, 2017 #3 what GPU are you using? IGPU? some GPUs have a maximum resolution that wont allow higher resolutions. if your monitor or TV allows only 1080p you shouldnt be able to go higher! 1200 is higher that 1080p. Upvote 0 Downvote
K keeezual Reputable Dec 3, 2015 47 0 4,540 Aug 3, 2017 #4 rgd1101 : if is only 1080p why are you setting to 1600x1200? Native is 1920x1080. The max i can set it to is only 1600x1200, theres no option for 1920x1080 Upvote 0 Downvote
