nikoli707 :
... most would agree that 1.40v@65c is as high as you want to run 24/7/365.
honey2015 :
wait, if people pushing 1.45V on 6700K which is 14nm, how than 1.3V is considered possible not safe for Haswell/Devil ?
Guys,
Different Microarchitectures such as 65, 45, 32, 22 and 14 nanometers have different maximum recommended Core voltages, so don't confuse Haswell / Devil's Canyon Vcore with Sky Lake / Kaby Lake Vcore.
Also, here's the recommended operating range for Core temperature:
80°C
Hot (100% Load)
75°C
Warm
70°C
Warm (Heavy Load)
60°C
Norm
50°C
Norm (Medium Load)
40°C
Norm
30°C
Cool (Idle)
25°C
Cool
Keep in mind that load and idle Core temperatures are influenced by Ambient temperature. Normal or Standard is 22°C or 72°F.
Overclocking is always limited by two factors; voltage and temperature. No two processors are identical; each processor is unique in voltage tolerance, thermal behavior and overclocking potential, which is often referred to as the "silicon lottery" or luck of the draw.
We know that excessive heat over time damages electronics, so even when using manual Vcore settings,
excessive Vcore and Core temperature may result in accelerated "Electromigration" -
https://www.google.com/?gws_rd=ssl#q=Electromigration
This prematurely erodes the traces and junctions within the processor's layers and nano-circuits, which will eventually result in blue-screen crashes that become increasingly frequent over time.
CPU's are more susceptible to Electromigration with each Die-shrink, however, Intel's advances in FinFET technology have improved the voltage tolerance of their 14 nanometer Microarchitecture.
Here’s a list of maximum recommended Vcore settings:
-> Core i
7th Generation 14 nanometer ... 1.400 Vcore
6th Generation 14 nanometer ... 1.400 Vcore
5th Generation 14 nanometer ... 1.400 Vcore
4th Generation 22 nanometer ... 1.300 Vcore
3rd Generation 22 nanometer ... 1.300 Vcore
2nd Generation 32 nanometer ... 1.350 Vcore
Previous (1st) Generation 45 nanometer ... 1.400 Vcore
-> Core 2
Legacy 45 nanometer ... 1.400 Vcore
Legacy 65 nanometer ... 1.500 Vcore
When tweaking your processor near it's highest overclock, keep in mind that for an increase of 100 MHz, a corresponding increase of about 50 millivolts (0.050) is needed to maintain stability. If 75 to 100 millivolts or more is needed for the next stable 100 MHz increase, it means your processor is overclocked beyond it's capability.
With high TDP air or liquid cooling you might reach the Vcore limit before 80°C. With low-end cooling you’ll reach 80°C before the Vcore limit. Regardless, whichever limit you reach first is where you should stop and declare victory.
Remember to keep overclocking in perspective. For example, the difference between 4.5 GHz and 4.6 Ghz is less than 2.3%, which has no noticeable impact on overall system performance. It simply isn’t worth pushing your processor beyond recommended Core voltage and Core temperature limits just to squeeze out another 100 MHz.
You might want to give this a read:
Intel Temperature Guide -
http://www.tomshardware.com/forum/id-1800828/intel-temperature-guide.html
CT
