Just bought a Maximus VIII Hero with Core i5 6600K. The motherboard doesn't boot. Sometimes the on-board Start and Reset buttons are lit, otherwise they don't. When they do, if i plug in any USB peripheral in the USB Bios Flashback port, the Start and Reset buttons start to blink. Tried pressing the Bios flash button for 3-10 seconds, nothing happens. There is no Q-Code on the digital display no matter what. There is no on-board LED lit up no matter what. The CPU fan doesn't start. The ROG logo doesn't light up.
I tried everything I found on the web, nothing worked. What I have tried includes:
- CMOS battery plugged out for few mins and then put back in
- Used a screwdriver to short the CMOS battery connectors
- Switched the CMOS reset jumper and powered on
- Checked CPU socket pins, they are not bent or anything
- Took out the board out of the case
- Only CPU, Cooler, 8-pin CPU power and 20+4 power and CPU fan connected
- Took out the CPU and tried booting the board only
- Tried with 1 DIMM in proper slot
- Tried without DIMMs - no beeps
- Tried USB Bios flash (with BIOS update appropriately named)
- Tried on-board buttons for Start, Reset, Bios reset, MemOK
With the mobo and CPU included, my build is:
Skylake Build
Before, and currently, because the new board isn't working, my build is:
Old Core 2 Quad Build
I know the PSU isn't great, and should have been replaced for the upgrade. But it has no problems whatsoever with Q6600 and a GTX960 installed, even when I let it run thru the night or when I play games. One thing to note though, my old board requires only 4-pin CPU power. I'm thinking it might be a PSU issue (maybe the other 4-pins aren't working).
So my question is:
1. Is there something else I can try before returning the mobo
2. Is there any part in my build that requires attention, other than mobo problem
Edited: I types 970 instead of 960. I just have one GPU GTX960.
Points to consider (if it comes to buying/replacing parts)
I live outside the US
After spending this much on Hero and 6600K I'm really tight on budget
Skylake Build
So my question is:
