I heve read that before, motherboard itself disables two SATA posrt (5,6) when connect both m.2 ports. All the other onboard devices shares PCH lines (USB, Audio, Raid, SATA, etc.). Is it matters that m.2 drivers run on RAID0 and add an extra Raid support? Can I disable some extra USB hub don't need all of them will that add an extra line or bandwich?
Thanks for replay. So RAID0 is not great idea as one of the slots will be down on half the speed and so whole RAID config. Only thing when test RAID setup with ATTO it shows stock speeds form my drivers and write speed was even slightly higher. My drivers are two ADATA SX8200PRO 512GB stock speeds 3350/2350.
