Hi
I want to have 2 extra front panels on my pc - 1 for reading sd cards - and 1 with speaker / mic + 4 usbs and a firewire.
the sd panel has a header connector to MB -
Q: where do i put it?
The usb/ firewire has plugs and jacks for ports - I want to strip the wires and put MB connectors on them.
Q: how do I connect the speaker/ mic wires to the one AAFP and does that shut the back panel ports as I do need them ?
If sd card goes to usb - then I'm one short.
Q: can I use the ieee1394 as I don't need firewire i front(there is one in back panel)
I would like these connections done internally - pins and crimptools are not a problem.
the MB I'm using is Asus P5WD2 Premium
