I just built an HTPC. I converted a working PCs guts to do it. It ran fine for a day, then it started randomly shutting down. After about 30 minutes it shut down and tried to reboot itself, but it would shut down immediately and cycle through the process again and again without success. I immediately thought heat or PSU. I swapped the PSU and got the same result. I installed Speedfan to monitor the temps and they were all blue (around 30 degrees C) right up until shutdown.
I took everything out until all that was left was the MB & CPU (no HDD or SSD or cards) and RAM. I alternated the RAM sticks (I have 2) in different slots with the same result. I uninstalled and reinstalled the MB in case something was shorted. I pulled the heatsink and reapplied thermal paste (after cleaning).
It will now run for a limited time (5-10 minutes) then start the rebooting sequence all over again.
The MB is an Asrock H67M-GE and the CPU is an i3-2105.
I'm looking for any suggestions, because I have run out of ideas.
Thanks.
Thanks.
