I'm a little new to actual guts and temps and all that stuff. I replaced my old mb and CPU with a
Processor: Core i7-2700k
PSU: Same voltages seem normal in bios
MB: Msi H61M-P31-/W8 (http://www.newegg.com/Product/Product.aspx?Item=N82E16813130659)
Old motherboard: http://www.findlaptopdriver.com/pegatron-corporation-2acf-specs/
So I'm just going start with my story if this could help you guys in some shape or form. I simply wanted a better processor, to get this I would need a new motherboard. Because the other computer was pre installed with all of that stuff when I bought it HP did all the driver stuff for me. After switching I backed up my stuff and let HP re install like I stated before it started well. However I noticed the CPU usage is VERY low and I could type faster than the computer can keep up with. This made me very scared and I'm somewhat on a budget so I can't go very high here. I've already used the drivers that came with the motherboard and still just starting Internet explorer or something simple raises the CPU up to 37-80%. I saw videos and reviews of this and nobody seemed to have problems. And recently it has just started to randomly shut off only minutes after turn on sometimes even roughly 30 seconds. Please help me or give me any tips or clues I could use. The system I got up and running about yesterday. If this helps at what I could find is that my pc seems to believe its 8 core and CPU-Z claiming its running at 800mhz... Please help me...
