Hi all,
Apologies if this is in the wrong place. I chose the components for my computer and had the company put it together for me. When I first started it, I noticed that it was quite noisy at first, but didn't think much off it at the time, I was just excited to have a new computer which was a vast improvement over my old one. To date I haven't done any tweaking to anything, apart from looking at the fans in the BIOS, Corsair iCue and Gigabyte SIV.
Components
Gigabyte Z390 Ultra
i7-8700k
Corsair H115i Platinum
Gigabyte RTX2080
Corsair Vengeance RGB PRO RAM
Corsair RM750x PSU
3x Corsair LL120 case fans
Fractal Meshify C Case
Now for the part that confuses me. According to following screenshots, you can see that the fan is running constantly at high RPM, and it cannot be changed. I tried changing it in the BIOS and SIV with no difference at all.
Below is the CPU Fan header, I presume that is connected correctly, but sadly my knowledge isn't that great with internal components and various connections.
At the end of the day, I can accept the fan noise, I'm just curious as to whether there is anything that I can do to control the fan RPM.
Thanks to everything in advance, hopefully I will be able to increase my knowledge and decrease noise levels!
Components
Gigabyte Z390 Ultra
i7-8700k
Gigabyte RTX2080
Corsair RM750x PSU
