G
Guest
Guest
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I am using a D-Link 713P AP with 64-bit Encryption enabled. My Media Center
2005 PC has a D-Link DWL-G520 wireless adapter (with latest drivers)
configured with the same Key as the AP. I also have a laptop running XP Pro
(SP1) configured with the same Key as the AP.
THE PROBLEM: Although signal strength is high, the Media Center PC looses
connection with the AP after a few minutes. However, the laptop connection
works fine. When encryption is disabled, both computers connect OK to the AP.
When I replace the DWL-G520 card with a Netgear WG311 (with latest drivers)
the behavior is the same as before: when Encryption is enabled the Media
Center PC looses connection after a few minutes. When Encryption is disabled
the Media Center connection is OK.
Does anyone have a solution to this problem?
Thanks in advance!
Thanks in advance!
