MCP655 Pump cable query
alexkahn1
25
I have been building a new watercooled computer and I have a couple of MCP655 pumps. The pumps have the standard black and red power cable, but they also have a single pin pale blue wire.
The single pin takes up one pin hole in a 3-pin connector on the end.
Does anyone know what this pale blue cable is for? What does it do? Where should I plug it in to?
It looks like it should go on the motherboard but I have never heard of a pump being linked to the mobo before.
Any help would be appreciated.
Hey,
The one cable attached to a 3pin fan connector is for you to be able to monitor the speed (RPM) of the pump. If the pump were to fail it would alert your motherboard of a "fan failure." The pump itself is still powered directly off the power supply (unless you have a PWM version, where it is possible to control it through a fan header).
Hope this helps!
Hey,
Hope this helps!
