G galacticsithgt Prominent Aug 30, 2017 15 0 510 Sep 14, 2017 #1 So what is the meaning of wireless network adapter? and does Asus Maximus IX Hero have a built-in wireless network adapter? Thanks in advance!
Solution manddy123 Sep 14, 2017 It's just a piece of hardware that'll let you connect to the internet through the Wi-Fi just as you'd do with a smartphone, but using your PC instead. No, it does not. ( or at least i couldn't find it in this page https://www.asus.com/br/Motherboards/ROG-MAXIMUS-IX-HERO/specifications/ )
The Paladin Titan Ambassador Oct 5, 2016 9,659 63 75,340 Sep 14, 2017 #2 wireless network adaptor is more commonly known as WI-FI adaptor. your manual will tell you if your board has it or not : https://www.manualslib.com/products/Asus-Maximus-Ix-Hero-8657999.html happy reading Upvote 0 Downvote
manddy123 Admirable Aug 25, 2016 1,956 0 6,960 Sep 14, 2017 Solution #3 It's just a piece of hardware that'll let you connect to the internet through the Wi-Fi just as you'd do with a smartphone, but using your PC instead. No, it does not. ( or at least i couldn't find it in this page https://www.asus.com/br/Motherboards/ROG-MAXIMUS-IX-HERO/specifications/ ) Upvote 1 Downvote Solution
G galacticsithgt Prominent Aug 30, 2017 15 0 510 Sep 14, 2017 #4 well whats the meaning of wifi adaptor? Upvote 0 Downvote
B ben5768 Reputable Dec 17, 2015 103 0 4,710 Sep 14, 2017 #5 as far as I'm aware your motherboard doesn't have one a wireless network adaptor is just something that allows you to connect to the internet without a direct connection like ethernet examples of a wireless network adaptors https://www.google.co.uk/search?q=wireless+network+adapter&rlz=1C1CHBF_en-GBGB760GB760&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjV0YaWxaTWAhXQLFAKHTmEDFwQ_AUICygC&biw=1278&bih=434 spoiler alert: some may actually have a wire like a usb cable so that you can place it somewhere to receive the best connection to your router Upvote 1 Downvote
The Paladin Titan Ambassador Oct 5, 2016 9,659 63 75,340 Sep 14, 2017 #6 galacticsithgt : well whats the meaning of wifi adaptor? maybe your just too lazy to post that question directly to google? but here is what toms hardware say on the subjet; http://www.tomshardware.com/reviews/usb-wifi-adapter-guide,4108.html Upvote 0 Downvote
G galacticsithgt Prominent Aug 30, 2017 15 0 510 Sep 14, 2017 #7 The Paladin : galacticsithgt : well whats the meaning of wifi adaptor? maybe your just too lazy to post that question directly to google? but here is what toms hardware say on the subjet; http://www.tomshardware.com/reviews/usb-wifi-adapter-guide,4108.html Searched it but haven't found any good results Upvote 0 Downvote
