I am starting my first build, and it will probably be my last too, I just want one that I can put together myself and will last for a long time, anyways.
will a Cooler Master Hyper D92 fit in a thermaltake chaser A71 case with a ASUS Z97-A motherboard? and I've read that heat sinks can be large enough to make it so some ram won't fit. so will the G. SKILL Rip jaws Z series 32gb (4x8gb) fit in with it too?
thanks in advance!
(links for reference)
RAM- http://www.newegg.com/Product/Product.aspx?Item=N82E16820231529&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Case- http://www.newegg.com/Product/Product.aspx?Item=N82E16811133223&cm_re=thermaltake_full_atx-_-11-133-223-_-Product
CPU Cooler- http://www.newegg.com/Product/Product.aspx?Item=N82E16835103108&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
thanks in advance!
