I'm trying to make the best decision regarding airflow and cooling mechanical hard drives in my new Fractal Define R5.
I have two 140mm intake fans on the front and one 140mm exhaust fan on the rear.
For the best air flow, I am considering removing the double optical bay cage at the top.
This space can then be used to mount the drive cage using the mesh ontop of the case.
This would increase airflow as my drives/cage wont obstruct the middle/bottom front of the case, where my 2 intakes are, delivering cooler air to my GPU, and potentiality the CPU too.
However having 2 mechanical hard drives with no direct airflow is something I am concerned about, especially since my SSD (c
drive will also be caged here.
So,
Is it safe to mount 2 HDD & 1 SSD into a cage that will receive no direct airflow?
They will likely be in a dead-zone in terms of air flow, the heat would only dissipate through the mountings and case surface.
Thanks!
So,
Thanks!
